We are using Autocad 2017 network on Windows 7.
We just encounter two issues:
1. It happened once, all dynamic blocks that have Visibility setting, the Visibility went missing. Other dynamic features remains in the block and it remains as dynamic block.
2. All Area Field attribute blocks of closed polylines are now MText. With that it will not update the area once pline is changed, which we do not want. Question is why and how it changed to MText from a Field. Again this happen on a particular dwg only, not every dwg.
Please advise. Thanks
mcmk
