I very new to the dynamic blocks and all but I was wondering if the following can be done.
The “Bord” and “Lijn” are attributes and I would like the to move along a line when the bar is rotated. The rotation I can do but the movement of the attributes is more of a problem. Can it be done that when i rotate the bar that the atribute moves along the line?
Thanks in advance
Solved by Libbya. Go to Solution.
It can probably be done using a double lookup. If you want further assistance, post the block. The image fine is not particularly useful.
I attached the dwg.
Can you show me how to work with lookup or give a general direction or manual on lookup?
Can you draw some examples of how you want the attribute to move when the block is rotated? "Move along a line" is too vague.
I will post a screencast in the following post. It will demonstrate step-by-step how to make your block do what you are asking for.
