Dynamic block and attribute movement along a line
Message 1 of 8
I very new to the dynamic blocks and all but I was wondering if the following can be done.
The “Bord” and “Lijn” are attributes and I would like the to move along a line when the bar is rotated. The rotation I can do but the movement of the attributes is more of a problem. Can it be done that when i rotate the bar that the atribute moves along the line?
Thanks in advance
Replies (7)
Message 2 of 8
Libbya
It can probably be done using a double lookup.  If you want further assistance, post the block.  The image fine is not particularly useful.
Message 3 of 8
I attached the dwg.
Can you show me how to work with lookup or give a general direction or manual on lookup?
Message 4 of 8
Libbya
Can you draw some examples of how you want the attribute to move when the block is rotated?  "Move along a line" is too vague.
Message 5 of 8
I did the drawing in the dwg with the steps I want the block to make
Message 6 of 8
Libbya
I will post a screencast in the following post.  It will demonstrate step-by-step how to make your block do what you are asking for.
Message 7 of 8
Libbya
Screencast is currently not working.  Ugh!
Message 8 of 8
Libbya
