I'm trying to improve my skills with dynamic blocks and arrays within AutoCAD LT.
I want to create a dynamic block for the setting out of screw and dowel holes for a cabinet (just circles). The first and last holes should be set 50mm back There should be a minimum 100mm and maximum 200mm between the larger holes.
For starters I'd really like to be able to first create a block or array that as I stretch from one end it keeps the sets of holes evenly spaced. Taking things a step further I would really the block/array to add another set of holes when the spacing exceeds 200mm and remove a set of holes when it the spacing drops below 100mm.
I think unsure of the best way to achieve this without parametric constraints- either dynamic block or array, and I'd apricate any help/advice.
Thanks in advance!
Solved by j.palmeL29YX. Go to Solution.
Attached two example blocks.
The one: the distance between the holes will never be smaller than 100.
The other: the distance between the holes will never be larger than 200.
(You must decide yourself which of the variants better meats your goal)
Give it a try.
(I hope ACAD LT can do the job, I can't test it)
Jürgen Palme
Hi Jurgen,
That's great, thankyou. I appreciate your time in doing this for me!
