09:16 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I know this issue has been posted alot & usually the answer is attsync but that doesnt seem to fix my problem. I have a dynamic block that has a series of visibility states which have different attributes which when you pick on the different states it displays different notes. I have modified the block to display different text in a slightly different order. the problem is that one of the options is not displaying the right text. I'm hoping i dont have to recreate this thing from the start. It is attribute number 38 when you look at it in the block editor. When the block is inserted into the drawing i get the wrong text. I did copy some of the attributes around & renamed them.
