Door that can stretch and flip
Message 1 of 10
Hi guys, can you please help me fix my door block:
I need the door width to strech, as well as the frame width and also be able to do a horizontal and vertical flip. Pretty basic but can't get it to work.
I followed this youtube tutorial (LINK) to create a simple door. To this I want to add a flip option. The horizontal flip works great but when I add the vertical flip the block is broken.
Replies (9)
Message 2 of 10
ojuris
where is block (dwg file)?
Message 3 of 10
j.palmeL29YX
Post your block please.
Jürgen Palme
Message 4 of 10
JBerns
You may also want to review the sample block on the AutoCAD Tool Palette - Architectural
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 5 of 10
So sorry for not replying sooner, my email notifications were turned off for some reason. Here is the block I don't know why it didn't upload in the original post
Message 6 of 10
j.palmeL29YX
Delete the Flip Parameter from the selection set of Stretch3.
Add a Move Action with Multiplicator 0.5 to the Thickness Parameter as shown in the video.
(view in My Videos)
Jürgen Palme
Message 7 of 10
Thanks, I tried your suggestion and now the flip parameters move correctly when the door frame is stretched. Now all that I want to do is to also add the flip in the other direction (left-right). Like @JBerns suggested I looked at the block from the tool palette and it seems that the flip parameter includes everything in it's selection set. But when I tried that it doesn't work in my case. You can see it in this video
Again thanks for your help!
Message 8 of 10
JBerns
@Anonymous,
The drawing you supplied contains six versions of the door block.
The version named, swing-door-screen, seems to have a working horizontal Flip definition.
CAD Administrator
Message 9 of 10
Thanks JBerns I will check that out. I actually changed the door block from the tool palette like you suggested and simply added a door frame and deleted the other visibility parameters as I don’t need those. And it works great 👍 I’m new to dynamic blocks so I still don’t perfectly understand how everything works but at least I achieved the desired result.
Message 10 of 10
JBerns
@Anonymous,
Glad to hear that you are making progress.
I would encourage you to watch any forum posts by @Libbya.
Also, see these Autodesk University classes:
https://www.autodesk.com/autodesk-university/search?query=dynamic+block
Looking forward to hearing of your success.
Jerry
CAD Administrator
