Editing a block revert to default or completely ignore changes
ManueleDesign
Message 1 of 1
ManueleDesign
Hi everyone,
I have a surreal problem that I can’t solve, I've already spent few hours on the net looking for a solution without any luck.
We're using Autcad 2022, in several files we have the same dynamic block used and modified many times during the previous months.
Yesterday the client asked for a small change to the geometry of the block and here happened a mess with diversified behaviors.
We have a large file, with many other blocks, in which if I edit the block and save it all similar blocks in the drawing (270) revert to the default.
We also have 5 other smaller files in which the same dynamic block is present, the changes in this case are completely ignored. Actually opening the block I can see those changes (in detail a profile that must become 26mm from 24) but in the general drawing the 24mm profile is displayed. It seems there is a cache of the block itself that keeps the old settings ignoring the editing.
To fix this problem I have to reset all the blocks and change them manually.
Any idea? I'm getting crazy, this can seriously compromize the way we approach projects.
Looking forward to hear any kind of suggestion.
Thanks in advance, sorry for my bad (getting worse) english.
Manuele
Replies (0)
