Door Symbol
Door Symbol
roy_bobo
Observer Observer
Door Symbol
roy_bobo
Observer
Observer
New to AutoCad LT, how do I place a door symbol?  The quick references says go to ToolPalettes and select the symbol but it's not working.
Thanks in advance for your help
Roy
Brock_Olly
If you type CTRL + 3 or use the command TOOLPALETTES, you should get a window like this.
Navigate to the 'Architectural' tab.
If you click a pre-made block like the 'Door - Metric' block, you can click anywhere in the drawing and it will place it down.
roy_bobo
Observer
Observer
thanks for your help; I was missing the Architecture tab
pkomatlapalli
Hi @roy_bobo,
Welcome to the Autodesk Community!
Just checking in—did the response shared by Brock_Olly help answer your question?
If so, please consider clicking the “Accept Solution” button. This helps other community members quickly find helpful answers and can also benefit others with similar questions.
Thanks for being part of the community!
Pavan Kumar | Community Manager
