- Mute
- Permalink
- Report
So this block(s) have become horribly convoluted, but I can't really backtrack and start over, so I have what I have. This is designed to display a TV elevation with a bracket and soundbar, in various configurations and layouts. To simplify things, I'm only attaching the "TV and Soundbar" block within an otherwise complex set of blocks. Knowing the answer to how to fix this one will help me fix the other 2.
I have a 'chart' at the bottom of the block which allows me to select a TV brand and model, which uses a lookup table to stretch a rectangle into the correct dimensions of the TV I've selected. Based on all of the dimensions that are on the drawing, we want to clean things up and put some of those standard dimensions on the chart to reduce the visible dimension lines. I tried creating attributes, and text fields, which pull the information from the linear parameter distance, but I'm just getting ### for information.
Drawing attached. Any idea what I'm doing wrong? Whatever the solution, I 'really' don't want to redo the Block Table, so if there's an easy solution, I'd be thrilled. You can click on the "Samsung" drop down, select a different TV, and the size/shape with change along with an updated weight (the rightmost number). Now I just need the Height/Width/Depth to show up also. I can't remember how I did the weight one.
