difference between parameters and parameter sets?
i cant seem to find this answer anywhere even though it seems like it would pop up alot.
but what is the difference between parameters and parameter sets in block editor?
edwin.prakoso
They are the same. Both methods will give the exact same result.
  1. Parameters only place the parameter and you can define the action later.
  2. Parameters set place a parameter and an action at once. However, you will need to define the selection set later anyway. You can add more action to parameters in this set if you need to.
I prefer to place a parameter first, then the action. I feel I have more control with this method.
Cheers,
Edwin Prakoso
ojuris
hi!
There is not big difference
with parameter sets you ad both - parameter and action
if you ad only parameter - after you must add action for that parameter
but
for example you can change parameter set Lookup set and add one more table and you can add Double lookup to block
