Customize Quick Properties for Dynamic Parameters
jk1173
Message 1 of 8
jk1173
Is there a way to customize what is shown in quick properties for dynamic parameters?  The only way you can see the parameters is when in block editor, but editing the CUI in block editor isn't allowed.  When not in block editor, the only parameter you can change is the visibility parameter.  Any suggestions or is this just a bug saying you have the option to change something but in fact can't?
Jared - Sr. Structural Designer
Words to live by: If it ain't broke, you're not trying hard enough.
Replies (7)
Message 2 of 8
mromagnoli
Dear @jk1173
What's version of AutoCAD using?
I would recommend that you update your AutoCAD, I'm not sure but I think it's already been incorporated several versions ago. I'll pass you a screenshot of 2023 where you can see the option "Display Dynamic Properties"
I hope this helps you.
Greetings.
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
Message 3 of 8
jk1173
I'm using 2022 - haven't had the time to update to 2023.  2022 has that section under Block Reference and mine is already checked.  Guess since I've got a little breather before the end of the workday, I'll update and see if the needed option has been added.  Thanks,
Message 4 of 8
h_s_walker
Yeah the Block dynamic properties have been in since (maybe before) LT2016 as that is my version of AutoCAD
Howard Walker
Left Handed and Proud
Message 5 of 8
-Igor-
If you tried the fix as suggested by @mromagnoli, then the next thing I would do is look at the block itself. Are the properties you are trying to see included in the visibility state? Are the properties set to not show.
Message 6 of 8
mromagnoli
Good contribution @-Igor- 🤙
Dear @jk1173
If you think we have helped you solve the problem, please like and mark them as solutions so that it will be easier for other forum members to find them.
Greetings 🤠
Message 7 of 8
jk1173
Well, weirdly enough I found a fix that is working - the suggestions provided weren't really addressing my issue.  I updated to 2023 earlier this month.  When in block editor, when I click an action, this is what I get in quick properties.
If I click the link to customize, I get the usual response in the command bar that you can't edit the CUI while in block editor.  If I then close the editor and enter the CUI, the last action I tried to customize is now added to the list and I can add what properties I want.
Now I get this.
Just tried it on parameters and it works for them as well.  As you can see on the previous image above, linear parameters is not listed, but after doing this workaround, it now is added and I can add properties.  Knew there "should" be a way to do this but don't get why it's not more straightforward.
Message 8 of 8
DragonDesigns
Hi, jumping on this post, AutoCAD 2027, anyone else having issues with this, all check boxes in custom are checked, yet they don't appear in QP
