I have seen so many people searching for a dynamic block that allows you to add weld symbols quickly to your drawing, and to be quite honest, I was one of those searching for this simple solution. I have seen many variants of what I've created here, but I found this to be the simplest and easiest block I've used to date, and not because I'm biased based on the fact I authored it:)
This is a dynamic block for AutoCAD that allows you to select from multiple common welding symbols so you can add them with ease to your drawing. You can select the flag type, the weld type, along with options to flip from left to right. Also available is the option to move the leader and stretch the tail of the symbol to accommodate for lengthy dimensional information. I authored this block mainly because AutoCAD doesn't have a built in Welding symbol library, and this was a simple solution I'm sure thousands of others have searched for. I plan on adding contour information to the block in the near future, but for now, this will accommodate most of your notation needs, as it does mine.
Weld Types included:
Fillet
Plug/Slot
Spot/Projection
Stud
Seam
Back
Backing
Surfacing
Flange Corner
Flange Edge
Square
V-Groove
U-Groove
J-Groove
Flare V
Flare Bevel
Scarf Brazed joint
Please comment and let me know how this works for you, and if there is anything you'd like to see added or if there is some functionality you'd like to see or even dropped from the block. Thank you!
