Constrain different dynamic blocks
dslaterAE9UD
dslaterAE9UD
I'm wanting to vertically and horizontally constrain section details that will be dynamic blocks to an elevation drawing that will also be a dynamic block. Whenever I add a parametric constraint to a dynamic block outside of it, the drop down goes invisible. Is there any way around this or is there a reason for this?
j.palmeL29YX
Post your file(s) or at least an exemple what you want to do.
Jürgen Palme
dslaterAE9UD
Of course. See attached.
j.palmeL29YX
After adding any geometric constraints to a Dynamic Block reference you can not change its properties (actions)  via the grips of the Dynamic parameters. You should consider to change the properties via the Properties window.
>>Click<<
Jürgen Palme
j.palmeL29YX
@dslaterAE9UD
Do you really need/want different widths in the XXO variant? (see attached image)
Jürgen Palme
