Setting minimum distances on 2 linear parameters that will engage by using only 1 stretch action.
nicolas.ramirezHH9R4
Observer Observer
Observer
Observer
I have a dynamic block of a counter top that contains seams and cut-outs for equipment.
My question is: How do I generate stretch actions that trigger minimum distances for multiple linear parameters?
I've attached a PDF drawing of what I am trying to achieve and a DWG of the counter top.
Let me know if anyone needs any additional information.
rogier.dejongCB9QW
Hi Nicolas,
When I download and open your dwg file, I don't see a dynamic block.
But when you're in the block editor and select on of the linear parameter with the stretch action assigned to it, you can set the minimum and maximum values in the Properties.
Is this what you mean?
