AutoCAD LT - Dynamic Blocks - How??
simon2WLRW
Message 1 of 11
simon2WLRW
Hi, apologies for the new person question, but Im having trouble creating a dynamic block.
I have created a block of a 4 panel door. I go into block editor and select linear and select the top left(start point) and top right (top right), it then asks me to place the label loction (the label doesnt appear) and the number of grips (2,1, or 0). Ive tried them all and nothing happens. Does this even work on LT??
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (10)
Message 2 of 11
handjonathan
Hello @simon2WLRW
Thanks a lot for posting your question to the forums!  
For the community to help you best, it would be great to have some more details from your end.  
  • Sample drawing file
  • Any screenshots showing the issue
Looking forward to hearing back from you with more information so we as a community can help you.
Jonathan Hand
Technical Marketing Manager | Construction
Message 3 of 11
Libbya
Dynamic parameters/actions work fine with LT.  Constraints do not.  Your process sounds right enough, but after adding any parameter, you need to add an appropriate action, associate it with the parameter and select the items it will affect.  Use Autodesk Screencast (free) to make a short video of your process and post it up if you need further assistance.
Message 4 of 11
simon2WLRW
Hi please see link below to a screen cast showing the issue. Any help is greatly appreciated
https://autode.sk/3LbOvSp
Message 5 of 11
Libbya
At 0:23 while it asks for the number of grips, what was your response?  Did you hit [enter], or [esc], or something else?
Message 6 of 11
Libbya
...also, post the file.
Message 7 of 11
simon2WLRW
Hi, thanks for having a look, I hit enter.
Message 8 of 11
Libbya
Where's the file?
Message 9 of 11
simon2WLRW
Hi there,
Thanks so much again. File is attached
Message 10 of 11
h_s_walker
Layer 0 is turned off. Parameters and actions are put on Layer 0. Turn it back on. See the image below
Howard Walker
Left Handed and Proud
Message 11 of 11
simon2WLRW
Thanks so much, its working...kind of. I might need to redraw the block, but I can work that out with the usual guidance. Many Thanks to all of you for your help
