- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im trying to create a block where the user selects a state using a lookup-dropdown function.
In this block is an attribute that I would like to change value based on the selected state.
(in this example are only 3 states, but there will be more in the end)
Is this possible in any way?
I've looked into using another lookup, but that seems not to be able to change the value of my att based on state.
(to be more clear: I want the "test"-attribute visible in all 3 states, but have the value change based on the visual state, IE: 0 in State 1, 15 in State 2 and 30 in state 3. I can't use 3 seperate attributes and have them change visibility; it has to be just 1 attribute)
