Change scale and position for elements inside a dynamic block
mauri.land
mauri.land
Hi everyone, I'm wondering what's wrong with my block.
I created a block for piping: I can change the diameter, stretch the length and also insert curves at the ends.
But I have a problem: a) if I stretch the length and THEN I change the diameter, the curves are scaled correctly but they move. Instead, b) if I change the diameter and then stretch the length, the curves are scaled correctly and are in the correct position too.
Can anyone help me?
I'm using Autocad LT 2023
mauri.land
Any help please?
j.palmeL29YX
- deleted -
Jürgen Palme
j.palmeL29YX
While the last days I was able to achieve some partial successes, as demonstraded here:
But before I spend more time to this issue we have to clarify some questions. See the attached .dwg file please.
Jürgen Palme
j.palmeL29YX
Attached a suggestion how you can solve your main problem (the arcs move away).
The vis. states are not yet added, that should not be a problem for you.
HTH
Jürgen Palme
j.palmeL29YX
Maybe you haven't figured out yet how i would solve the problem.
Attached a video which shows the "kernel" of my suggestion.
Feel free to ask if you have further question.
Jürgen Palme
mauri.land
Thank you very much for your help! I'm watching the video and your solution, and I'll be able to study it in some day because of the intense work in this period, but I'll let you know! thank you again
