Dynamic block: scaling a circle around a center point using diameter
mrichardsKN4R4
Observer Observer
mrichardsKN4R4
Observer
Observer
Goal 1: Dynamic block for a tree trunk (existing trees to remain) that can be scaled around its center point by entering its diameter in the properties panel.
Problem: Linear parameter + scale action only lets me scale by radius, or scales diameter from one edge of the circle, not from the center.
Goal 2: Tie an attribute to the parameter so that you can enter the DBH on block insertion, instead of opening properties.  I'm not actually sure if this is possible, but I remember having a block with similar functionality in a previous office.
j.palmeL29YX
goal 1:
see attached suggestion
goal 2: "... enter the DBH on block insertion"   ???
Jürgen Palme
mrichardsKN4R4
Observer
Observer
Thanks for #1 - that works.
#2 - sorry,  Tree lingo.  DBH = diameter at breast height.   I want to be able to set the diameter of the symbol when I insert it.  The block also has a "tree tag" attribute definition, so I don't want to just scale the entire block.
j.palmeL29YX
BTW: If you want to set the diameter during the insert, you don't need any dynamic block. Create a "normal" block with diameter=1 and set the scalefactor to the whished diamter while you insert the block. Or what I'm missing?
Jürgen Palme
j.palmeL29YX
Oops, I read this after posting my previous answer.
If you need an attribute which "reflects" the current diameter, you can scale the block while inserting and use an attribute whose default value is a field which reads as blockplaceholder the current scale factor. Doesn't that meet your goal?
Jürgen Palme
mrichardsKN4R4
Observer
Observer
Not quite, because scaling the block on insertion will still scale my other attribute text - unless I'm missing something?
j.palmeL29YX
Not quite, because ...
Ok, that happens if we know only the half of the truth  😉
At the moment I don't know further help.
Jürgen Palme
