Message 1 of 8
06:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
Im creating a block which contains 3 text attributes. the block text must rotate depending on the angle positioning of the block. Right now i get one of the text to rotate but i cannot link the 3 rotates to do the same by linking this other two rotate parameter to the main rotate one. Could anyone explain me how to chain reaction this 3 parameters?
in other words:
i would text1 and text2 to rotate from their own middle center points the same angle as when the rotate parameter from text3 is modified. Is this possible?
thanks in advance
J.
