Center text grip not centered properly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to fix a block, but I have the same issue when I just try to create single line text outside of the block. The text is centered in each "cell", but when I choose any center alignment option, the center grip is not centered in the text, making the alignment off center. If I change the font, the center grip changes position, but I need to use Arial. I have tried all of the suggestions I could find including ATTSYNC, but the only thing that works so far is TXT2MTXT. I could go through and change them all to mtext, but I still don't have a fix for the attributes. Does anyone know why this is happening? I'm using AutoCAD LT 2021 and operating on Windows 10 Pro.
Attaching a block. I dragged it into a new drawing, so some of the text converted to standard, but you can see the difference.
