I'm struggling with this simple tag block "Tag.dwg". I can't seem to get this tag to funcion properly.
What am I doing wrong?
I want my simple annotation tag arrow to be easily rotated 0, 90, 180, and 270 degrees. But everything I try for rotation ends up separating the arrow's polar strecth fuction from the arrow itself.
Can anyone help me?
I basically just want the straight arrow to rotate like "Tag Before.dwg", and the arrow stretching part to work like it does in "Tag.dwg"
Solved by Libbya. Go to Solution.
Are you saying you want the segment of the arrow between the tag rectangle and the first polar grip to rotate at 90° intervals, but you want to be able to place the tip of the arrow anywhere (allow any angle to the leg from first polar grip to tip of arrow) and have it stretch appropriately?
Why did you make all the parameters chained? What were you expecting as a result of doing so?
I turned off chain options and now it works perfectly. Such a relief!
Thank you for the help.
