Can it be automatically extended when it rotates?
truss_85
truss_85
Greetings;
I have block simple that has some rotation action. When it rotates upper lines must be strecth positively and lower ones must be strecth negatively. I did that with 3 grips in attached block. I just want to know is there a way that when it rotates strecth action can be done automatically. Any idea will be apprecieated.
Thanks in advence.
h_s_walker
Why don't you use a POLAR STRETCH?
See the attached drawing
Howard Walker
Left Handed and Proud
truss_85
Thank you for answering;
Sure might be but I have two specific problems to avoid polar stretch:
Firstly, Green and red lines must have relatively rotate to each other. (Angle1)
Secondly, vertical line must have rotate half of Angle1. (Angle2=Angle1/2)
When you use polar stretch vertical line cannot rotate half of relative rotation and polar stretch has a second problem which is make same colored lines  narrower or wider.
h_s_walker
Am I to understand that the "Final result" for the lines needs to look like an X?
Howard Walker
truss_85
No it is not. İt is the opposite of X. For different angles see attached file.
truss_85
May be I did not very clear about what I want. sorry about that. I want in every angle d1 and d3 parameters may stretching depend on rotate parameter not by hand.
h_s_walker
Sorry. I don't understand at all what you want and I've only got LT so I can't work with constraints
Howard Walker
