Camera FOV Coverage
Camera FOV Coverage
mikejach
Message 1 of 11
Camera FOV Coverage
mikejach
I'm trying to make a dynamic block to represent the camera FOV coverage for CCTV. I'd like a grip on the block to adjust the FOV to be wider or narrower, a grip to lengthen or shorten the area, and then another grip to rotate the whole block. I've figured out how to do each of these 3 things using constraints, but when they are all added together and I try to rotate the block, I get the "One or more constrained objects cannot be resolved." I'm not sure which one is causing the error.
I've tried doing it with stretch actions, but those caused more problems.
Replies (10)
Message 2 of 11
Libbya
The issue is that you are combining constraints and dynamic parameters/actions (rotate).  If you do the rotation using an angular constraint it works fine.  See screencast.
Message 3 of 11
Libbya
Alternatively I could do it all with dynamic parameters/actions and the grips will move more intelligently, but the block would be much more complicated.
Message 4 of 11
j.palmeL29YX
I did some small modifications to the blockdefinition. Try if this is ok for you.
cadder
Jürgen Palme
Message 5 of 11
j.palmeL29YX
Ignore my last post. It's not yet working properly. 😞
Coming soon.
cadder
Jürgen Palme
Message 6 of 11
Libbya
Coming soon.
cadder
Coming soon?  I posted a screencast that shows step-by-step how to get it working properly prior to your first post.
Message 7 of 11
j.palmeL29YX
Here a new version. Now it should work.
And sorry for posting my last post twice. I'm new in this forum and have had some trouble with the correct handling.
cadder
Jürgen Palme
Message 8 of 11
j.palmeL29YX
Ok, sorry again. I did'n want to affond you nor ignore your suggestion. I tried to find another solution. And because the author did not yet mark this thread as "solved" I guess he is not happy with this solution (?).
Once again, excuse me if there was a misunderstanding.
cadder
Jürgen Palme
Message 9 of 11
mikejach
Thank you so much! That's what I was looking for. There were other ways I could get it to work, but it's nicer to have the grips follow the block.
Message 10 of 11
smrifas
@Libbya & @j.palmeL29YX
Could you please provide a solution that includes dynamic blindspot (can be increase and reduce) in the coverage
it will be very help full, below image is the example
Thanks in Advanced
Message 11 of 11
j.palmeL29YX
One of surely several ways ...
Jürgen Palme
