Message 1 of 11
- Mute
- Permalink
- Report
I'm trying to make a dynamic block to represent the camera FOV coverage for CCTV. I'd like a grip on the block to adjust the FOV to be wider or narrower, a grip to lengthen or shorten the area, and then another grip to rotate the whole block. I've figured out how to do each of these 3 things using constraints, but when they are all added together and I try to rotate the block, I get the "One or more constrained objects cannot be resolved." I'm not sure which one is causing the error.
I've tried doing it with stretch actions, but those caused more problems.
