Dynamic Blocks Forum
Call out blocks
2 REPLIES 2
315 Views, 2 Replies
Call out blocks
I am trying to set a call out block to scale to the dimscale not to scale of 1 for multi scale drawings
2 REPLIES 2
You probably need a lisp routine to insert the block at the current dimscale.
If you use ADT, all this is automated with mvblocks and aeccontent.
wrote in message news:4912760@discussion.autodesk.com...
If you are comfortable with the palette interface, and if scaling to
DIMSCALE is adequate for your needs, then,
1) create a palette item
2) right click on it
3) select Properties
4) choose "Auxiliary Scale" under the Insert header
5) set this property to "Dimscale"
If you use this interface, you can also control the properties listed
under "General," which includes LAYER, among other (related) things.
Otherwise, .
Forma Design Contest
