Hi all,
I'm fairly new with dynamics block and I would like to have some help for the cable block that I'm creating for working with logical schematics directly in AutoCAD.
As you can see I'm trying to have a block that I can stretch from the end point and the fine tuning from the middle point, but when I move the end point from the end point, the first time, only the bottom line stretch and then the block start to work correctly.
Also, I would like to make the end point parameter to stay fixed to the end point when I tune from the middle, but In don't know how to fix it there (the move parameter obviously is not correct because when moving the middle point the end stretch) basically I need it to move vertically following the bottom line.
Thanks in advance,
Sorry for the late reply and my poor explanation, but that was exactly what I was thinking.
Never thought of using the XY parameter instead of move.
Thank you so much for your help!
