Dynamic Blocks Forum
Blocos com atributos
10 REPLIES 10
Message 1 of 11
706 Views, 10 Replies
How to make blocks with visibility parameters and that it is possible to detrude one of your trash cans through a list, as shown in the attached file?
Tags (1)
10 REPLIES 10
Message 2 of 11
hwalker
Welcome to the Forums
The bottom block was easy. Search for double look ups here. They will show you how I did it.
The top block not so much. You'd have to create 216 visibility states for each combination of symbol and text
Howard Walker
Left Handed and Proud
Message 3 of 11
in reply to: hwalker
Hello! Many thanks to the front desk and especially for the help! It was excellent! But I wanted to ask you a favor: I researched a lot on the internet and I did not find anything like your great explanation. Would it be possible for you to record a Screencast for me to learn how to do too? I have other files to perform this procedure! I would be very grateful!
Message 4 of 11
hwalker
I shall do one tomorrow. I'm on my way home now
Howard Walker
Message 5 of 11
Libbya
Here's a screencast that shows one way.
Message 6 of 11
hwalker
Attached is a screencast showing how I did the block
Howard Walker
Message 7 of 11
Hello my friend! I would like to thank you very much for your help! I learned a lot! But I had another question: I followed the step-by-step of your video but in the end, when I change the type of extinct (PQS ABC, PQS AB, etc.) the "LOAD" does not appear in all types. Could you help me? I made a video and I'm also sending the file that I made so you can help me.
Screencast: http://autode.sk/2wlXJU4
Message 8 of 11
hwalker
You just needed to change the visibility of the object so it appears in all visibility states.
Right click on the item move to OBJECT VISIBILITY and choose SHOW FOR ALL STATES.
See the attached drawing
Howard Walker
Message 9 of 11
steven-g
Here is the first block, a start anyway, just adapt the lookup for the rest of the values, it looks like you have some of the values entered twice in the list and this will only work with unique values so I changed a few
Message 10 of 11
Hello, hwalker!
I would like to thank you again for your help! I'm attaching a file that shows the blocks I've set up with your help!
Now I'm trying to make one more change: is there any way to make an automatic counter in the blocks for each time I copy the block, it changes the number, example: 1, 2, 3, 4, etc., but at the same time , when I exclude a block, the numbering is updated in the other blocks?
Message 11 of 11
hwalker
You would need lisp to do that.
I do not know how to use lisp. I'm sure someone else should be able to help you
Howard Walker
Autodesk Customer Advisory Groups
”Boost
