Block That Requires User Input
patrickmahoney21
Message 1 of 9
patrickmahoney21
I am creating a cui file that calls out dwgs for blocks. I am creating a ceiling diffures (i.e. a rectrangle with an x through it) and I need to know how to make the block so when the user clicks on the button it asks the user to specify the x distance and y distance of the rectangle. For example if I want to place a 12X24 Ceiling return diffuser, when I click the button I want the pormpt to ask the user to specify the X-distance of 12" and the Y-distance of 24"
Replies (8)
Message 2 of 9
j.palmeL29YX
Are you looking for somethin like this?
Or this?
Or, which workflow do you prefer?
Jürgen Palme
Message 3 of 9
patrickmahoney21
Like the first link you posted but I am using tool bar with cui file not a tool pallet.
Message 4 of 9
j.palmeL29YX
Ok. The "secret behind the stage" is a small LISP. Attached a rough draft (quick and dirty) to show the principle.
You can run this LISP from wherever you want. (Of course it must be loaded before). The Tool Palette is only an example.
Jürgen Palme
Message 5 of 9
patrickmahoney21
Thank you
Message 6 of 9
patrickmahoney21
Where do I load the LISP File? In options?
Message 7 of 9
j.palmeL29YX
- In the command line you can type
Command: (load "YourLispFile.lsp")
- You can use the APPLOAD command. If you always need the LISP, drag the LISP-file into the StartUp Suite.
- You can put the (load ...) command(s) (as mentioned above) in an acad.lsp or acaddoc.lsp
For further informations I'd suggest to ask (or search before ) in the LISP Forum (e.g. here).
Jürgen Palme
Message 8 of 9
patrickmahoney21
So if my block dwg name is rect. here is my lisp I loaded
(defun c:rect.dwg (/)
(load rect.dwg)
(Setq X_Dist (Getreal "\nX-Distance: ")
Y_Dist (Getreal "\nY-Distance: ")
P0 (Getpoint "\nInsertpoint: ")
P1 (list (+ (car P0) X_Dist) (cadr P0))
P2 (list (car P1) (+ (cadr P1) Y_Dist))
P3 (list (car P0) (+ (cadr P0) Y_Dist))
(command "_rectang" P0 P2)
(command "_line" P0 P2 "")
(command "_line" P1 P3 "")
And in the cui macro I wrote
^C^C(load;"TEMP.LSP") to load the lisp when I click the button but it does not work?
Message 9 of 9
j.palmeL29YX
(load rect.dwg)
No no. It can't work this way.
Obviously you're not familiar with LISP.
Therefore some explanations:
- With (defun c:MyCommand ... ) you define a new command which you can type at the AutoCAD command prompt (or any other way). It never can include a dot (as in your example "rect.dwg".) .
- The LISP command (load ...) loads a LISP file, not an AutoCAD dwg.
I'd suggest this way (as one of any possibilities):
- Create a LISP file as shown here again (I did some small refinements). It is named is diffusor.lsp. Save it anywhere in your suppor path. This LISP defines a new command "xrec".
- Now you can use the following macro (first it loads the LISP file, then it starts the xrec command):
^C^C(load "diffusor");xrec;
BTW: This has nothing to do with blocks. Tis only draws the needed geometry (a rectang and two lines) with the distances you have typed.
Jürgen Palme
