Vis States and Attributes
jlogan208
jlogan208
I have built a test Title Block for two different size borders with one attributed title block and an approval stamp.
Three Vis States
STDSL = Border Only - STD size
STDMAX = Border Only - MAX size
STDSL_ATT = Attributed Approval stamp and the STDSL border
I've placed the Attributed title block in the drawing but not as part of the dynamic block, as it will reside in each Vis State and need to be edited.
My steps
Started with a blank drawing
Entered BE at the command line
Selected <Current Drawing>
Built all of my Vis States
Inserted each border and Approval stamp into their correct and current Vis States
Exploded the Approval Stamp block
Saved As and exited.
When I start a new drawing and insert the test TB, my...
Title Block cannot be edited.
Vis States work fine.
Approval stamp can be edited.
Clearly I'm missing a step or doing something wrong.
J. Logan
Ultimately I want to be able to have 5 or 6 vis states for various attributed approval stamps and two vis states without the stamps.
J. Logan
CAD Administrator >AutoDesk Products, Windows 11
jlogan208
A little move forward...
I changed my approach.
Created a drawing, we'll call it the Standard Title block. In it exists only the Attributed title block and nothing else.
Saved and exited.
Opened it and inserted the dynamic block that contains my two borders and approval stamp all in their respective Vis States.
All seems to work just fine.
J. Logan
J. Logan
jlogan208
Still more follow up...
I've created a lookup table that includes 4 vis states. When I select any vis state from the lookup table, the lookup table grip disappears. I can still select from the properties tool palette to change them back.
I have...
"Right Click Menu" checked in Options.
I've tried turning the setting the grips to <0> and <1>
I've turned off the grip for the Visibility States.
I've searched the forum and some topics come close but nothing
quite the same and all of the suggested fixes haven't seemed to pan out.
J. Logan
J. Logan
vinodkl
The problem here is you have not made the lookup parameter to be visible in all the visibilty state, so when you switch to second visiblity state the lookup grip was not showing up. I have made that change. Also the STDTB_ND2 visibility was not set in the lookup table I have added that also. In the visiblity state STBTD_ND and  STBTD_ND2 I could see only text under the heading NETWORK DIAGRAM APPROVAL instead of attributes, are these values constant? if not change it attributes as you have done in other visibility state STDTB_SL.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
jlogan208
Thanks for looking.  It never crossed my mind that I had to work with each state for each lookup. Good to know. The rest of the stuff you mention, I was aware of. I just wanted to get a "working" start and deal with the minutiae after that.
Thanks again for the help.
J. Logan
J. Logan
