Block shows as different scale but inserts correctly
martinowen32
Message 1 of 22
martinowen32
Hope someone can help me with this issue, so I'll try to be clear;
For years, I've had a pallette of 30 or so blocks
All insert fine at the correct scale and the 'preview' when you click a block is fine
Recently, 2 of these blocks appear much larger when clicked on the toolpallette but still insert at the correct scale (so the scale settings are ok).
Obviously this visual appearance is annoying with appearing to insert much larger, but only for 2 of my dynamic blocks
Can someone advise? If i redefine the block first, it's fine. But I don't want to have to do this every time I start a new drawing.
Thanks in advance.
Replies (21)
Message 21 of 22
martinowen32
Also both millimetres
Message 22 of 22
h_s_walker
You've got me stumped then.
I can't think of any other settings which change
Howard Walker
Left Handed and Proud
