Block shows as different scale but inserts correctly
martinowen32
Message 1 of 22
martinowen32
Hope someone can help me with this issue, so I'll try to be clear;
For years, I've had a pallette of 30 or so blocks
All insert fine at the correct scale and the 'preview' when you click a block is fine
Recently, 2 of these blocks appear much larger when clicked on the toolpallette but still insert at the correct scale (so the scale settings are ok).
Obviously this visual appearance is annoying with appearing to insert much larger, but only for 2 of my dynamic blocks
Can someone advise? If i redefine the block first, it's fine. But I don't want to have to do this every time I start a new drawing.
Thanks in advance.
Replies (21)
Message 2 of 22
martinowen32
*Update*:
I've noticed the 2 blocks in question are set to inches in the units. I've gone to the source file but it shows correctly as mm.
If I insert the block and check the properties....it's shown as inches, even though the source file shows mm. I'm confused - can someone help?
Message 3 of 22
h_s_walker
At the command line type INSUNITS. What are they? Change them to millimeters. Personally I have mine set to UNITLESS
Howard Walker
Left Handed and Proud
Message 4 of 22
martinowen32
Hi, thanks - I'd already changed these to mm unfortunately.
Weirdly enough all units are set to mm APART from when the block is inserted then selected.... please see attached
1. units shown in block editor
2. units shown of main dwg of block
3. units shown of new drawing with block inserted
All dwg units are mm in all settings. I honestly don't know how to change this!
Message 5 of 22
h_s_walker
Can you post a drawing with one block with the correct settings and the block that inserts at the wrong scale
Howard Walker
Message 6 of 22
martinowen32
It does insert at the correct scale - it's purely when the block is selected from the pallette, the visual is larger, then when clicked and placed onto the modelspace, the scale is fine
Message 7 of 22
martinowen32
Also, if I redefine the block, everything is then correct and the visual is back to the correct scale (still inserts correct) and when highlighted the block units are now mm. But I don't want to have to redefine every time I open a drawing
Message 8 of 22
h_s_walker
Ok that sounds like there is already a block in your drawing with that name. Check the block in the drawing itself and see what the units are for that block.
Howard Walker
Message 9 of 22
martinowen32
This is odd thing - the units are fine in the drawing. It's literally only when the block is placed in a new drawing, and only these 2 blocks. No other blocks of that name as they're all called something different.
Message 10 of 22
pendean
Community Legend
Community Legend
Post DWG files please, lets see these issues for ourselves.
thx
Message 11 of 22
martinowen32
Attached is the dwg of one of the problem blocks. Not sure if you can see the issues from this alone, but feel free to! It's incredibly annoying!
Message 12 of 22
h_s_walker
I just opened your drawing and opened up the block in the block editor (I did nothing else) and as you can see from the image below the units of the block are set as inches, change them to millimeters, don't forget to save the changes and also recreate the tool palette icon by selecting the new block and dragging it onto the tool palette
Howard Walker
Message 13 of 22
martinowen32
here's the kicker....I've done that! It's like it won't save. It changes, saves, shows correct in the drawing, then if I start a new one it goes back to inches!
Message 14 of 22
h_s_walker
Ok do a quick select and find all instances of the block in your drawing and delete them.
Then do a PURGE to get rid of the block from the drawing completely.
Copy the drawing I've attached and then try reinserting the block from that drawing.
I've changed the units to millimeters and already drag and dropped it into a blank drawing and it stayed as millimeters
Howard Walker
Message 15 of 22
martinowen32
Followed that exactly, shows as mm in the drawing it's from, but in a new drawing still shows as inches! Sorry 😞
Message 16 of 22
h_s_walker
Can you post a picture of the settings for your new drawing, without any objects in it at all (just a blank drawing)
Howard Walker
Message 17 of 22
martinowen32
what settings would you like to see?
Message 18 of 22
h_s_walker
Drawing units to start with.
At the command line type UNITS and post a screenshot of the dialog box.
Also at the command line again type DWGUNITS. What are the units set to there?
Howard Walker
Message 19 of 22
martinowen32
Attached
and set to mm in DWGUNITS
Message 20 of 22
h_s_walker
At the command line type OPTIONS. Now choose the USER PREFENCES TAB. What are the settings of the items ringed in the image below
Howard Walker
