Dynamic Blocks Forum
Batt Insulation Block
9 REPLIES 9
Message 1 of 10
20600 Views, 9 Replies
I am trying to make this insulation scale and array using dynamic blocks. I have it scaling using a list but the array does not work after the scale. Is there a way to set up the column offset to be equal to the scale factor? The attached file shows the problem. It works perfectly at 3". When scaled to 3 1/2" or more the problem starts.
Thank you in advance for your help.
9 REPLIES 9
Message 2 of 10
To do this using only built-in options, you will have to make a visibility state for each scale with appropriate array offset. The other option requires customization if you don't have AcadLT.
The attached is the way with customization. View the Readme to set up.
Message 3 of 10
here is mine.....insert it at a scale to suite the thickness required....of
you need 50mm thick insulation insert the block with a scale of 50..
Message 4 of 10
I have the same problem. Did you ever find a solution?
Message 5 of 10
The solutions have already been posted in this thread:-)
Message 6 of 10
I just wanted to say thank you very much for posting the insulation block, it was a great help.
Message 7 of 10
Libbya
Mine is a totally different concept that gives additional functionality.
Message 8 of 10
serkancavuslar
New Super RockWool
Serkan ÇAVUŞLAR
CplCAD / Türkiye
Message 9 of 10
in reply to: Libbya
Thank you for the Block - finally it's works !!!!
Message 10 of 10
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
AutoCAD Inside the Factory
