AutoSaving each Variants in separate Dwg
I have a master Dwg where there is N Number of Variants But I need A separate Dwg for Each Variant It's really Hard to open and Save as each variant.Is there any other solution to this problem
Thanks in Advance!
maratovich
What is Variant?
Attach an example of your file.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
I have attached a Sample dwg -Shapes where the Dwg contains many Shapes in a Single dwg But I need to save in it separate dwg for each shape-Rectangle.Dwg.Circle.Dwg.Triangle.Dwg... Not by manual but by some Command or Something else Because there is quit many Variant it's really hard to do it manually!
pendean
Community Legend
Community Legend
WBLOCK command is the built-in tool, if you want  to do it faster you will need to automate with all the built in customization tools.
You need to be posting in one of the customziation forums, not here: try the AUTOLISP forum first found here https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
