automated stair elevation - array issue
HwLeeGBC
HwLeeGBC
Hi all, I'm trying to make a stair for elevations that can automatically match unit rise and run by changing number of steps.
the issue is the array for the steps, it modify the block in unpredictable way
Variables:
the block can be modified in height and length
number of steps can be modified in block reference
steps rise and run adjust are self adjusting through changing number of steps
HwLeeGBC
ps
the array path curve would be D1
HwLeeGBC
any help would be appreciated or even negative feedback if such kind of array is not possible
Libbya
I don't think that what you are trying to do is possible using an array.  You might be able to simulate an array using visibility states and a double-lookup and get it to work but it would be very complicated/advanced and I'm not even sure if that is possible.
HwLeeGBC
Thanks, I bypassed with another path, it work but need one more step.
