Dear all,
please find attached dynamic block of gusset plate knee brace.
I can not able to add vertical parameter
Krish
Solved by j.palmeL29YX. Go to Solution.
What action should this vertical parameter execute? How should the block look after changing its value?
Furthermore - currently you have a mix of dynamic parameters/actions and constraints. That will not work properly.
Please describe completely what you want to achieve, independently of your current attempt to solve. How should the block work, which geometry/dimensions do you want to "manipulate".
Jürgen Palme
hi, thanks for the reply.
vertical parameter to be able stretch so that the height of the plate can be reduced increased accordingly.
very similar to the link below. He has not added the vertical parameter otherwise everything is as per this.
Here one of several variants how you can build the gusset plate.
Give it a try.
Jürgen Palme
this is purely perfect (99.9%). But only one parameter along legs can be added then it can be applied on all sizes.
Three variants are attached.
Jürgen Palme
