Dynamic Blocks Forum
autodesk dynamic blocks gusset plate - knee bracing
9 REPLIES 9
Message 1 of 10
coolkris
550 Views, 9 Replies
Dear all,
please find attached dynamic block of gusset plate knee brace.
I can not able to add vertical parameter
Krish
9 REPLIES 9
Message 2 of 10
j.palmeL29YX
in reply to: coolkris
What action should this vertical parameter execute? How should the block look after changing its value?
Furthermore - currently you have a mix of dynamic parameters/actions and constraints. That will not work properly.
Please describe completely what you want to achieve, independently of your current attempt to solve. How should the block work, which geometry/dimensions do you want to "manipulate".
Jürgen Palme
Message 3 of 10
coolkris
hi, thanks for the reply.
vertical parameter to be able stretch so that the height of the plate can be reduced increased accordingly.
very similar to the link below. He has not added the vertical parameter otherwise everything is as per this.
https://www.youtube.com/watch?app=desktop&v=r8cUAmS59xs
Message 4 of 10
j.palmeL29YX
Here one of several variants how you can build the gusset plate.
Give it a try.
Jürgen Palme
Message 5 of 10
coolkris
this is purely perfect (99.9%). But only one parameter along legs can be added then it can be applied on all sizes.
Message 6 of 10
coolkris
Please find attached
Message 7 of 10
j.palmeL29YX
Three variants are attached.
Jürgen Palme
Message 8 of 10
j.palmeL29YX
@coolkris wrote:
this is purely perfect (99.9%). But ...
Could I reach the 100% >>now<<😉
Jürgen Palme
Message 9 of 10
coolkris
in reply to: j.palmeL29YX
You deserve it thanks 🙏🏿
Message 10 of 10
coolkris
Forma Design Contest
