AutoCAD Dynamic Block Scalebar and Automatic Visibility depending on Viewport
kieran.leadbetter
kieran.leadbetter
Hello, does anyone know how to make a dynamic block scalebar change its visiblity depending on the scale used within a viewport.
They have the same names so Scale of 1:50, the Dynamic block has a scale called 1:50, the scalebars all look slightly different so I don't want to put fields into the block itself, I want it to automatically change the visibility depending on whatever the scale of the viewport becomes if that makes sense. Kind of like a link between the viewport and dynamic block?
Thank you
h_s_walker
You cannot link information inside a dynamic block to information outside a dynamic block.
You can however put the scale of the viewport in mtext as a field. See the image below. The grey text is the field and it is linked to the viewport (magenta line) and will update after a refresh if the viewport scale is changed
Howard Walker
Left Handed and Proud
kieran.leadbetter
I tried that, but we plot our drawings at A1 due to a plotting issue at A3, but we still print them at A3, causing an issue in the object field to 2:1, any idea of how to get that field?
I've attempted for ages to adjust the field code so that instead of the field saying 1:#, I could change it to 2:#,
Basically the scale used would be 1:100, but we would need to write in the scale box that the scale is 1:50 due to the paper being half the size
h_s_walker
If you don't use annotative objects, change the field from the standard scale to custom scale and then in the properties change the annotation scale of the viewport
Howard Walker
