Autocad Dynamic block 3D extrude
valotaire_emile
valotaire_emile
Hello
  1. How do you add a linear parameter that modifies the height of the extrusion?
  2. Is it possible to put a parameter that would allow you to modify the elevation of the block according to the z-axis?
h_s_walker
You can't. Dynamic blocks are only 2D
Howard Walker
Left Handed and Proud
R.Gerritsen4967
You can only add parameters in the same plane, so what you want is not possible with dynamic blocks.
If you only need a few distinct heights for the cube, you can make a dynamic block with some visibility states.
See attachment for a start of such a block.
j.palmeL29YX
For a simple box you can cheat with a surface model. To change the height use the properties panel.
For real (more complex) models this will not work.
Jürgen Palme
j.palmeL29YX
Jürgen Palme
