vertical parameter tos2 getting skewed when stretching horizontal parameter edge left
coolkris
coolkris
Dear All,
I am improving my dynamic block skills, I need to do pipesupport steel drawings.
I have made dynamic blocks 2 visibility states, In the 2nd visibility states having 2 pipes need to be stretched on both ways. I am having trouble when stretching horzontally the vertical parameter tos2 getting skewed and moving the column out of centre. I need expert help.
Krish
j.palmeL29YX
@coolkris wrote:
... trouble when stretching horzontally the vertical parameter tos2 getting skewed
This small defect can be solved if you increase the sketch frame of Sketch10 so it includes the tos2 parameter completely.
But that's not the only problem in the block. Your main mistake: You mixed Dynamic Parameters and Actions with Parametric Constraints. You should never do that. Define your block either using only and explicitely Dynamic Parameters/Actions, or completely only using dimensional and geometric constraints. A mix of both leads in most cases into a lot of trouble.
Jürgen Palme
coolkris
Still can we keep without dimensional constraints only object constrains some of the pipe and fittings are variable, will it not be too much to have stretchable parameter actions for small distances.
Krishna
j.palmeL29YX
>>object constrains + stretchable parameter actions<<
You can try it, in most cases the block will not work properly (but then do not complain 😉 ).
Jürgen Palme
