AutoCAD 2017 Getting Hashtags on my Text Fields when Publishing to PDF
JBurke
JBurke
Using AutoCAD 2017 Full Version on Windows 10 & Bluebeam PDF Full Version.
I'm having an issue with Text Field and Print to PDF.
I use the Text Field to add my sheet numbers to my dynamic block via the Sheet Set Manager.
Visually on AutoCAD, the Text looks great.
However, when I print (from the file or publish thru the Sheet Set Manager), the end result is Hashtags on my PDF file.
I would say it happens about 20% of the time.
I manage a dept of 5 detailers.  So it is hit and miss with everyone, not just one user.
Any ideas?
Thanks!
Jeremy
A couple of thoughts, maybe a solution?
I would first make sure that whatever PDF solution you are using is embedding the font that the text object is using.
Second, I would try another PDF product to see if the happens there.
Lastly, I would make sure it wasn't some sort of network access issue when plotting/publishing and AutoCAD is trying to access the DST file for the field information.
Thanks.
