Mtext Field Referencing Itself
Id like to have a Mtext object that shows its own X position. Ive entered a field and gone to object but i cant select itself. So i selected another Mtext object and set it to give the X position. I then copied the expression below. I then went into the selected Mtext object, entered a field, then used the formula option. I pasted the expression i copied and a field popped up with the correct value. If i click into the field, only the X checkbox is selected. As soon as i click OK. It displays the location of itself, but instead of just X. It displays X,Y and Z. I want it to display just X. I know this is sort of confusing, i tried to explain it the best i could. If you have any questions dont hesitate to ask. Thank you for your help.
