Attributes problem in dynamic block
Message 1 of 10
Can I using block properties table manage dimenisons that folow attributes nad visibility states?
Replies (9)
Message 2 of 10
Libbya
Yes, if the distances are managed by the table, the attribute values can be written by the BP table to match the distances.
Message 3 of 10
Short answer:  Yes.
Example is attached.
Message 4 of 10
Can you save it in older format of Acad because I cant open it
Message 5 of 10
I have tried it in attached file but dont know where the error is.
Message 6 of 10
Libbya
There is no file attached to your post.
Message 7 of 10
Here is attached file 🙂
Message 8 of 10
Libbya
The attributes are blank on the table.  I assume this is what you want.  See screencast:
Message 9 of 10
I am trying to do that dimensions (distance 1 and distance 2) match dimensions set in block properties table when I change visibility (which is set in Block properties table).
Message 10 of 10
Libbya
Ok, then you still need to fill in the cells of the table.  After that make the default values of the attributes match a row of the table.  You also have your two stretch actions associated with the base point of their respective linear parameters.  Because of that, when the table changes the length of the linear parameters, nothing happens to the block because the base point of the linear parameters remain stationary and the end points change... and because there are no actions associated with the end points, nothing happens.  See screencast.
