Attributes populated by Fields/lookup tables loose field association after attout/attin.
So... I have blocks with attributes and some of them get assigned via a list in a lookup table to control entries. If I extract the attributes via attout and then bring them back in via attin the fields are blown out and can no longer be changed via the lookup parameter. If you use a Block Properties table this does not happen but I have several attributes I want to have drop downs for and I'm not sure a matrix will work since the data does not relate in a good way. Am I missing something? Any work arounds aside from custom Lisp routine only exporting the attributes that do not have fields?
