Attributes populated by Fields/lookup tables loose field association after attout/attin.
Village_Idiot
Village_Idiot
So... I have blocks with attributes and some of them get assigned via a list in a lookup table to control entries.  If I extract the attributes via attout and then bring them back in via attin the fields are blown out and can no longer be changed via  the lookup parameter.  If you use a Block Properties table this does not happen but I have several attributes I want to have drop downs for and I'm not sure a matrix will work since the data does not relate in a good way.  Am I missing something?  Any work arounds aside from custom Lisp routine only exporting the attributes that do not have fields?
JTBWorld
Not sure of workarounds other than a 3rd party solution.
Try our app JTB BatchAttEdit.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
