What date & time field to choose ?
dvrVSNMW
dvrVSNMW
I don't know what time field I should use:
I have a dynamic block which should use the date it is changed to.
So when I change from one block to another, that date, when I change this should be the date. I don't know if that is possible? So the date must be set on the day I switch to "goedgekeurd". Is that possible, automatic?
The date now is correct because I made this today, but I noticed it is always the date when the drawing is made. I'm going to do some more testing tomorrow to see if it changes. But maybe someone of you knows this out of experience?
Regards.
DVR
h_s_walker
A date field will not update inside a block. I know I have a year field inside a block and it won't update without manually going into the block right clicking on the field and selecting UPDATE FIELD
Try the bold text above
Howard Walker
Left Handed and Proud
