Attribute repetition value in other internal blocks
hi everyone. I have an issue with attribs. in the attach you can see a dynamic block with a attribute and inside the dynamic block, other block with attribs. One of those attrib must have the value of i set when insert the block.
I tryied to leave the blank value in the default but dont work anyway.
Any help please and sorry about my english.
Regards
Clode
Libbya
You cannot affect the attribute value of nested blocks unless you enter block editor.  You can have multiple attributes with fields within a single block though.  See screencast.
Hi Libbya and thanks for the replay and the screencast.
The solution is working really fine but i need, after affect the dynamic block, explode them
and operate de blocks inside as i has inside the dynamic block.
About you say. i cant do this like i say buat thanks anyway by your effort.
Regards.
Clode
