ATTRIBUTE- AREA- ADDITION
I don't know how to define attribute which add 2 different area together.
MMcCall402
For the field in the attribute go to a Formula. In the formula insert a field for the first object's area + a field for the second object's area.  Basically, you're making a formula to add two fields together.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Libbya
Are the two areas and two attributes all within a single dynamic block?  Post the file.
fkp7057
Please check attached auto cad file you will get your answer in yellow highlighted text there is formula to sum both the area .
Hope this will help .
Thanks & regards
