Line type scale changed to when imported blocks to a different drawing
I have a problem where I made my blocks in the first floor drawing of a building and when I moved them to another drawing for another floor all the linetypescales changed to 2 from 1 and are frozen. I opened the second drawing and used design center to get the blocks from the other drawing. I don't want to go through and halve all of the line-weights so I want to figure out how this happened and what the solution is.
Potential issue could be that the global line type scale factor is set to different values between the drawings,this would cause the objects to behave differently. This can be changed by accessing the line type manager. This can be accessed as per the below screen cast.
Values within the line type manager can be saved within the drawing.
Hopefully this helps with your issue.
Charlie
