-ATTEDIT in dynamic blocks doesn't work
Message 1 of 1
Hello
I have several lisp routines with normal attedit lines, but it doesn't seem to work when my block is a dynamic block (the two visibility status I have are related to other things inside the block, not to the attribute I want to change).
When I go into "-attedit" "N" "N" "Myblock" "MyAttribute" "*" it doesn't detect it regardless if visibility status is 1 or 2. But it does work if I delete the second visibily status and it becomes a normal block, no problem then.
What is going on? I can't find anyone complaining about this so I may be skipping something.
Thank you
Regards
Replies (0)
