trying to combine a rotating block inside a visibility state block
AutoMarcus
AutoMarcus
ok so i have made an end view
and a front view
the end view rotates
id like to make a block where i combine the two so that i can switch between end and side view.
however i find i lose the rotation or movement when i put a rotating block inside another block.
for example please find attached end view and side view.
once combined i lose the movement or rotation i once had
Libbya
Of course you lose the grips to nested blocks.  They are only accessible within block editor.  If you want them accessible in model space that place the parameters in the host block, not the nested block.  Better yet, don't even use nested blocks just use the appropriate linework in the individual visibility states and use the appropriate rotation parameter(s) to rotate them.
Libbya
Here's a screencast.  Actions and parameters must go in the host drawing, not nested ones.
